Weird Sound When I drive
Old Jan 10, 2007 | 04:40 PM
a6lovely's Avatar
Member
Default Weird Sound When I drive
Hi Guys,
When I drive my car I hear like a squeeky noise like metal is not lubricated sort of a high pitch metal rubbing together on the front...
Whistle metal rubbing together that goes on a beat (wheeeeeeek wheek wheeeeek wheek Wheeeeeeek) kind of like that.
Could it be like a CV boot?
Anyone have experienced it before.
Thanks-
Old Jan 10, 2007 | 05:48 PM
madridlover's Avatar
Default RE: Weird Sound When I drive
Generally when a CV Boot goes bad you'll hear a clunking noise when you turn your wheels either right or left. The noise you describe could be anything. Maybe ball bearings, bad rotors, control bushings...who knows. Do you have a good indy mechanic?
Old Jan 10, 2007 | 05:55 PM
al_gordon's Avatar
I thought this would be a good place to join the forum because i also have a weird sound when I drive my 1999 Audi A6 Avant station wagon with only 80K miles.
When the steering wheel i turned to the right during turns, I hear a "chirping" sound coming from the center of the dashboard area. One other point to note is that the warning snowflake on the display blinks continuously at warmer temperatures -- even 60 degrees F, but properly stays lit at lower temperatures.
Have no idea what the problem is and since the car drives perfectly, I am hesitant to start incurring diagnostics costs at the Audi dealer.
Thought it might be related to the ABS system which seems to be operating correctly when the brakes are firmly applied on slippery roads, but until I hear some knowledgeable direction, I'm hesitant to do anything.
Old Jan 10, 2007 | 08:16 PM
a6lovely's Avatar
Member
Yeah I have a good mechanic, I should just turn it in to them...
It's just that I spend so much already fixing my car
When I turn my steering wheel there's no problem no sound just that when the car is moving straight forward...
Old Jan 10, 2007 | 09:20 PM
Fall0ut's Avatar
ORIGINAL: madridlover
oh oh, mine does that
Old Jan 10, 2007 | 10:00 PM
tractioncontrol's Avatar
A6lovely, I would check the brakes, the squealer may be touching. If it is an older car you may not have brake pad sensors and when you drive it may be just enough to touch the rotor.
Al-gordon, if the chirping sound happens anytime you turn the wheel (not necessarily driving) then I would assume it is the boot around the intermediate shaft at the base of the steering column where the shaft goes through the fire wall, it can be lubed with a quality silicone lubricant to stop the noise.
Old Jan 11, 2007 | 12:25 AM
a6lovely's Avatar
Member
Yeah, I have the 98Q 2.8 but I think I have the brake sensor...
I hope it's something minor I just replaced my upper and lower control arm about a month ago...
That ish cost me a lot of hard working dough...
ORIGINAL: tractioncontrol
Old Feb 21, 2008 | 11:04 PM
wesleypipes3.2's Avatar
May be that the power steering is low
tonygump
Oct 11, 2009 11:44 AM
1Move
Oct 6, 2007 01:11 PM
drkenan
Apr 26, 2007 02:56 AM
A4Petro
Jul 9, 2005 10:16 AM
