What oil do you guys recommend?
Old Mar 22, 2009 | 02:55 AM
  #21
CBurbs's Avatar
Quick question for all of you...
Just bought a 2007 A4 2.0T a few months ago and the oil light came on the other day after 3,000 miles. I checked the oil and it was a little low, so I stopped by Autozone and picked up a quart of Castrol Syntec SAE 5w-30. Prior to going to the store I did a quick search online and it appeared that this was the correct oil, but after further research it appears I should have gotten the 5w-40, rather than the 5w-30. Will it really make a difference if I only used 1 quart of oil? I assume everything will be fine and when I get the oil changed in 2,500 miles I will just make sure they use the correct oil. Just figured I would double check with you all.
Thanks!
Old Mar 22, 2009 | 03:22 AM
  #22
Midniteoyl's Avatar
It'll work.
Old Mar 22, 2009 | 03:25 AM
  #23
Midniteoyl's Avatar
While I love non-synthetic Rotella-T for break in, that one meets 'cj-4' which i believe is diesel oil.
http://www.apicj-4.org/faqs.html
Old Mar 22, 2009 | 03:18 PM
  #24
nemohm's Avatar
Mobil 1 5w-40 is not specified as an oil in production on mobil.com
You are referring to Mobil 1 Turbo Diesel Truck, right?
Old Mar 22, 2009 | 03:57 PM
  #25
Midniteoyl's Avatar
Nope... there must still be stock left at Walmart. Thus the reason I said 'by several'.
However.. Mobil 0w-40 is the replacement and is on Audi/VW's approved list.
Old Mar 22, 2009 | 04:58 PM
  #26
Midniteoyl's Avatar
jsethwerner225
Jun 25, 2010 05:45 PM
amrrashad
Sep 4, 2009 02:42 PM
samleong
Mar 3, 2009 08:02 PM
pred02
Jul 29, 2007 11:00 AM
Fall0ut
Dec 18, 2006 12:33 AM
