what is this and why...
Old Nov 20, 2008 | 07:57 PM
Coors's Avatar
Default what is this and why...
is there a fine oily mist on it?
I noticed the valve just under the silver y pipe and slightly in front of the firewall (center/rear of the engine bay) has an oily mist on it and its a-joining hoses. I assume it is a breather valve of some kind and may be possibly plugged. The valve has five hoses going in to it. 2 hoses on either side and 1 hoses going into the center.
Also, the valve that comes off of the right side of the silver y pipe looks similar to the valve slightly beneath it. (has a fine oily mist on it) Could this be plugged too? It looks really loose and looks like it may just fall out of the y pipe.
There are pictures of the 2 valves here:
https://www.audiforums.com/forum/members/coors-39786-albums-coors-357/
Thanks
E
Old Nov 20, 2008 | 08:24 PM
auditech79's Avatar
Thats the PCV valve and hose assembly, on the 2.7T you have to buy the entire assembly together. Search on www.ecstuning.com they have them there.
They do get plugged pretty easilly, and it causes an oil consumption problem.
Old Nov 20, 2008 | 11:26 PM
Coors's Avatar
Just ordered the kit from ecs, thank you
Old Nov 24, 2008 | 09:15 PM
Coors's Avatar
I just recieved my new breather hose assembly from ECS Tuning. I have a 01 C5 2.7T w/ 6 spd MTM. There was only one set-up listed on their site that is for the manual application. So, I know I ordered with the right part number
On the new assembly I have an extra nipple coming off of the top of 5-way valve. My old application does not have this.
Any ideas what to do with this exposed nipple?
My old set-up does not have this nipple. I would assume that this is for some sort of vacuum line.
What can I do about this exposed nipple. Will oil spew out of it if I do not plug it?
Take a look! Theres a picture of the new valve assembly and the old assembly here:
The first picture shows the new valve and the last picture shows the current valve
https://www.audiforums.com/forum/album.php?albumid=357
Old Nov 25, 2008 | 12:33 AM
auditech79's Avatar
Just plug the hole, that happens with our parts a lot.
Old Jan 9, 2009 | 02:36 PM
Coors's Avatar
Never got around to installing this. There is no way this is going to work on this car. The breather that comes off the Y-pipe comes straight out. The new one looks like it goes on to a Y-pipe set-up that has an offset breather assembly.
Is there 2 different breather assemblies? One for the straight out breather assembly on the Y-pipe and one for the offset breather assembly Y-pipe.
I just cannot make sense of this. Also some of the lines on the new assembly are way to long for my application. Even, if i cut the new assembly lines to fit, there would be no way to secure the tubing to the engine. Hose clamps won't work because its a heavy duty plastic.
What the hell?
AUDITECH79, PM SENT
Old Jan 9, 2009 | 03:21 PM
nemohm's Avatar
The dealers offer that spyder pipe (assembly) in 3 versions after the climate particulars.
Having wrong application would lead to same old problems => overpressure and gasket leakages.
Old Jan 9, 2009 | 04:37 PM
Coors's Avatar
I bought the assembly from ecs. They only had one for the manual. After running into this issue I went to my local dealer to comparer the parts. They didn't have one in stock for the manual, but the parts dept did show me a diagram of the part and it was the same one that I had in my hand.
I can't figure this out for the life of me. I know that my current part has not been modified by the previous owner because there are Audi/VW stampings all over it.
I have another 2000+ miles till my next oil change otherwise, I would just pay my mechanic to do this. My mechanic is 45+ miles away. I thought I would be able to just swap one out for the other. Go figure!
I have oil all over the current one, and it looks like the breather is just hanging off the side of the Y-pipe. So it needs to be changed out soon!
Old Jan 10, 2009 | 09:11 PM
auditech79's Avatar
Yeah there is only one for the manual model, it should be the correct one. Have you taken the old one out yet? I haven't had a problem getting one in yet, although its not an easy part to install if you haven't done one yet.
Old Jan 11, 2009 | 11:15 AM
Coors's Avatar
Nah, I haven't removed my current one yet. It's a little intimidating, being as the new one is completly different. Everyone keeps telling me this is the right one, you included. I think I'm going to let my mechanic handle it.
Its just that the main breather that comes off my silver y-pipe comes straight out. The new one fits on the angle silver y-pipe. I just dont see it fitting.
I guess thats why you are saying its sort of a challenge to install this guy.
Thanks for your help, man.
Eric
