What's this damaged tube for?
I noticed that this tube (see the red box in the image) was fitted incorrectly - the clip that hold it was pressing into it, more or less blocking it off completely.
https://www.audiforums.com/forum/att...1&d=1255961475
Here you can see the damage:
The tube is very stiff now and probably brittle- there's no way I can get it to open up again.
What's this tube for? Is it very important to get it fixed?
If you look right over the fuel pressure regulator, you'll see that the same "tubing" is bunched up with the sleeve of the power supplies that go to the purge and change over valves.
You can check what you have at the other end (below the air intake tube and purge valve), but I doubt is anything else other than a sleeve for electrical wires.
Thanks guys.
Yeah - that's what I was doing when I noticed the wiring harness
I have a new breather hose and purge valve, going to fit them soon.
BTW your vac lines are shot and you could use a little dusting in there! Jeese!
