What's this damaged tube for?
Old Oct 19, 2009 | 10:21 AM
divil's Avatar
Default What's this damaged tube for?
I noticed that this tube (see the red box in the image) was fitted incorrectly - the clip that hold it was pressing into it, more or less blocking it off completely.
https://www.audiforums.com/forum/att...1&d=1255961475
Here you can see the damage:
The tube is very stiff now and probably brittle- there's no way I can get it to open up again.
What's this tube for? Is it very important to get it fixed?
Old Oct 19, 2009 | 11:01 AM
chefro's Avatar
that seems to be just a "heat shield" or sleeve for some of the electric cables. I may be wrong though since I don't have anything like that running across the manifold in my C4.
Old Oct 19, 2009 | 11:04 AM
divil's Avatar
I should have mentioned it's a 1998 2.8 30V V6
Old Oct 19, 2009 | 11:13 AM
chefro's Avatar
If you look right over the fuel pressure regulator, you'll see that the same "tubing" is bunched up with the sleeve of the power supplies that go to the purge and change over valves.
You can check what you have at the other end (below the air intake tube and purge valve), but I doubt is anything else other than a sleeve for electrical wires.
Old Oct 19, 2009 | 12:26 PM
Midniteoyl's Avatar
^^ Believe he's correct... its a wiring harness crossover...
Old Oct 19, 2009 | 11:18 PM
Jackmup's Avatar
I would say the same!
It's fine leave it. It's just firmly secured.
BTW your vac lines are shot and you could use a little dusting in there! Jeese!
Old Oct 19, 2009 | 11:22 PM
Midniteoyl's Avatar
Think thast bad? Dont look under my hood.... I live on a dirt road
Old Oct 19, 2009 | 11:56 PM
auditech79's Avatar
Thats part of the wiring harness, i ran a whole new one when a 3.0L caught fire in the shop a while back.
Old Oct 20, 2009 | 08:23 AM
divil's Avatar
Thanks guys.
Yeah - that's what I was doing when I noticed the wiring harness I have a new breather hose and purge valve, going to fit them soon.
Ris888
May 7, 2013 12:27 AM
ThePizza
Sep 2, 2011 09:58 AM
auditamer
Oct 10, 2007 02:45 PM
shaudi*
Jul 18, 2007 07:50 PM
SAudi
Nov 10, 2006 07:38 PM
