Wheel fitment question
Old Aug 1, 2012 | 09:04 PM
04A64.2's Avatar
Default Wheel fitment question
I have an 04 A6 4.2 and I just got some 19" rims and 35 series tires. Ive seen A6's with up to 20" but i noticed In the front the upper control arm protrudes over the tire, im just hoping i have enough room. Does anything need modified for fitment? If/when I get everything mounted i'll throw up some pictures.
Thanks for any help
Old Aug 2, 2012 | 08:33 PM
04A64.2's Avatar
No one has 19"s? Also have a question about hooking up leds to my turnsignal wires. Couldnt get a good ground or the right wire, not sure what the problem is...
Old Aug 4, 2012 | 09:39 AM
CRF Rider 57's Avatar
Typically problems with LED's in turn signals are caused by not having enough resistance which causes the system to think the bulb has failed. There are resistors that you can buy to wire in to the system. If you go to Superbright LEDs they sell the resistors and specify which you will need. The resistors come with instruction though I would not use the "3M connectors" supplied with the kit, use a quality butt connector. I have purchased resistors for my LED turn signals and they work perfectly.
dgk910
Mar 31, 2010 01:31 PM
Cali_Avant
May 30, 2008 03:50 PM
neur0tic
Mar 20, 2007 05:30 PM
Flip
Mar 7, 2007 07:12 PM
jchussey
Sep 7, 2006 07:06 PM
