When door opens, mileage indicator is shown, anyone know what controls the light
my mileage indicator does not show when I open my door, is there a fuse or relay that controls this. I can not see any mileage or hear any beeping until my key is in the on position
It uses the door lock sensor. I'm assuming if you turn your lights on and leave the door open it won't beep at you - warning you that it will drain your battery? Happened to me as well and I had to replace the door lock assembly, since you cannot get just the sensor.
OK so I pulled back the carpet and took a good look at the wire harness/connector for the TCM. It is corroded. SO I went to the junkyard found a 4.2 A6 and removed the connector for the TCM. I disconnected my battery, and cut all the wires connected to the harness. rewired the new harness and hooked the TCM back up to the harness, and finally got the lights to show on the dash for the PRD12. now that it lights up that's great because I can see what gear it goes in. but that is not the problem now::
When I shift from (P to R to N) I can see that but when I shift to drive the limp mode light lights up. so I still am not able to get the car to move at all.
However changing this wire harness did control the shift brake light and sensor. it now locks like it should. could anyone tell me what the next step is to get closer to figuring out what it could be
lw89
Sep 24, 2013 06:46 PM
copper07
Feb 15, 2012 03:58 PM
