Where to fix a cracked rim?
Old Jan 27, 2009 | 08:51 PM
contacthansel's Avatar
Default Where to fix a cracked rim?
Hi all,
I have a 99 Avant and one of my rims got cracked from a wonderful Chicago pothole. Kept losing air in the tire and it turned out to be a hairline crack in the rim seen from the inner side. I have a friend that is a welder and says that he could weld the crack for me, is this recommendable? What kind of concerns should I have doing this? Or otherwise, what else could I do, or where else to go? Thanks!
Old Jan 27, 2009 | 09:01 PM
oc_audica's Avatar
try posting in regional?
Old Jan 28, 2009 | 12:47 AM
chefro's Avatar
Originally Posted by contacthansel
Hi all,
Do you have the 6-spoke OEM design?
If you do, you can buy one for around $ 75-85 - shipping included, and if the friend repairs the cracked one you can make that one into a full-size spare.
Old Jan 28, 2009 | 11:36 AM
no 6 spoke... i have the multispoke wheel. i'm trying to keep the costs down for this repair. my friend could weld it for $30 but i'm not sure if ill have super balancing problems. eh. i have these rims.
Old Jan 28, 2009 | 02:30 PM
ppgoal's Avatar
If it's not repaired right, it could fail under speed. I would strongly suggest you find a used rim.
Old Jan 28, 2009 | 08:10 PM
True, might as well spend a little more and just find a rim, do it once, instead of 3x the amount.
Old Jan 29, 2009 | 06:53 AM
bob martin's Avatar
I had a BMW rim welded with no issues. I had a shop do it (Pro Wheels in Detroit) as they need to find the end of the crack, drill a hole to stop the crack from spreading, then weld it up. The shop also repainted the rim. All for $100.
Bob
Old Jan 29, 2009 | 08:09 AM
DEE123's Avatar
Wink cracked rim ?
i am currently riding on two rims that has cracked before.i had them welded and have no problems ,yet. Balancing is perfect.my rims are irreplacable and i love them. I paid about $100.00 per wheel repair.rims are aluminum and the repaired rim must be placed on rear of vehicle.
Old Jan 29, 2009 | 08:18 AM
DEE123's Avatar
I had two cracked rims repaired and still ride on them today.they are alluminum and cost about $100.00 per rim average cost during my research.the only thing that you must do is make sure you put the repaired rim on rear of vehicle, in case of failure you do not lose steering. Dee-balto.md.
Old Jan 29, 2009 | 04:39 PM
NH_USA's Avatar
Get a used rim from either Force five in Concord NH or Shoken in PA --- Repairs are a bit iffy as showen by peoploe putting the repaired rim on the rear
insanoman85
Apr 12, 2010 06:50 AM
dbansal
Mar 19, 2009 01:34 AM
hotgrass
Feb 5, 2008 05:28 PM
duburban
Apr 24, 2007 11:58 PM
nitro_rider2001
Jan 17, 2007 04:09 AM
