Why would u need to replace a upper oil pan
Old Aug 11, 2015 | 03:24 PM
audia62000123's Avatar
Default Why would u need to replace a upper oil pan
Hey guys I would this Audi a6 2.8 online this guy is selling it for real cheap because he's moving all it needs is a upper oil pan and I just wanted to see if u guys new why that would go bad I no the lower one crakes from it hitting like a speed bump I just don't what to get in over my head
Old Aug 11, 2015 | 10:03 PM
Nebuchadnezzar's Avatar
Possibly someone fouled up when jacking up the car or maybe there is a leak at the gasket and the seller is assuming the pan needs to be replaced?
If I recall correctly the subframe needs to be dropped in order to access the upper oil pan gasket.
I turned away a friends bmw 3 series when he hit me up to do an oil pan gasket. I couldn't justify doing that job and dropping the sub frame to fix a phantom leak that I knew wasn't there but he was convinced it was because a shop told him it was. Fast forward 3 months later and surprise he's low on oil again and the piston rings are going.
Use caution with this purchase. If you're getting it for a good price and have the time I think it's a great buy. This would take the typical shade tree mechanic 2 weekends to complete.
Old Aug 13, 2015 | 04:48 AM
Thanks I'm looking at it tomorrow
Old Aug 13, 2015 | 11:33 PM
I found out he was jacking up the car and a block slip and knock the oil cooler off broke the oil cooler right off
vtraudt
Feb 28, 2011 08:40 PM
chefro
Jan 28, 2011 02:47 PM
sa9023
Nov 20, 2010 11:33 PM
kingofnyc22
Dec 11, 2009 10:40 PM
gsA6
Feb 1, 2008 09:10 PM
