window and electrical problem
Old Aug 15, 2007 | 08:33 PM
amandas004's Avatar
Default window and electrical problem
so i messed up my audi's electrical system. i was washing the car and i dumped a full bucket of water and cherry bomb soap on the car and i failed to realize that the front pass window was open half way. the whole pass side was soaked. at first the window worked fine, then after a half hour the window wouldn't budge but all the other windows worked fine. i dried all i could with paper towels and took off the door panel to dry that as well. after i took off the window switch and dried the connection, everything worked fine. next morning i open the door and it was so moist that the windows were fogged. and of course, the windows wouldn't move at all, the dome lights were out and the door courtesy lights wouldn't work. so i checked the fuse box and two fuses were blown. i put in a new fuse and it popped on contact. i think there is a ground near the power control module, or i probably fried it or something[&o]. if anyone has any information please let me know. thank you.
Old Aug 19, 2007 | 10:15 PM
melrose man's Avatar
Default RE: window and electrical problem
If you check my previous posts and read what Hadham has to offer in reply it might give you some idea of what the prob is
JC
BT5150
Oct 7, 2010 08:38 AM
Rodneylynn1977
Apr 11, 2010 03:15 PM
BMF!
Jan 24, 2009 12:23 PM
jahease
Mar 31, 2007 04:22 PM
