Windows
Old Dec 13, 2005 | 07:31 AM
twinblowersonice's Avatar
Default Windows
I got a 2001 A6 2.7T. The childlock button on the drivers door is broken and rear windows dont operate from the backseat. Anyone knows how to replace the switch? anybody with spare parts, let me know!
Old Dec 14, 2005 | 02:06 AM
neversummer's Avatar
Default RE: Windows
This is simple fix that does not require you removing the door panel. First you need to get the switch from Audi. When replaced this in my car the switch was around $80.00 dollars. Or if you feel lucky you can take the switch out and take it apart and try to clean the contacts. I would not recommend this unless you are very good and taking electronics apart. To remove the switch you need to open the driver side door all the way. You then need a flat head screw driver. You are going to be looking for a hole on the bottom of the handle that is under the switch itself. This hole is not near the door lever. The hole is designed not to be seen unless you are looking for it. But it is the only hole in the general area of the switch and door handle. Once you find the hole push the flat head screw driver into the hole. You need to push up and in. This will pop the switch and the trim around it out. The rest is pretty simple. Good luck.
Old Dec 14, 2005 | 02:21 AM
cary12's Avatar
Default RE: Windows
LOL. Same thing happened to mine but I haven't fixed it yet. Is there anywhere other than the stealership to get the switch?
Old Dec 15, 2005 | 05:04 AM
heisse_mkII's Avatar
Default RE: Windows
I kinda have the same problem. My child lock window switch won't disengage unless I hold it down. I hope it is a switch problem. Any place else that sells the switch than the stealership?
Old Dec 15, 2005 | 11:12 PM
Default RE: Windows
I found a couple of places online that are selling the switch. Germanautoparts.com is selling it for $74.20, but I think you have to pay for shipping. Also, you have to email with what part you want because it isn't on their online catalog. The other place is Drivewire.com. They are asking $75.90 with free shipping and no sales tax.
Old Dec 18, 2005 | 02:01 PM
Default RE: Windows
thanx for your help and support ya'll !!! Summer, I'm gonna use all my hole-searching skills and giterdunn LOL Seriously, though, $80 big ones, I'll try to fix it on my own first LOL - I'll let you know what I find out
armyboy91083
Feb 14, 2010 01:44 PM
striker451
Sep 4, 2009 03:44 PM
samantha_audi
Oct 4, 2008 08:39 PM
phillyfan1290
Nov 27, 2007 06:42 AM
cary12
Jan 30, 2006 02:07 AM
