Windows roll down with door controls- not up with with door controls but with key
Old Feb 14, 2012 | 12:57 PM
copper07's Avatar
Default Windows roll down with door controls- not up with with door controls but with key
1998 A6 Quattro - 176k
Last night I rolled down the drivers window then it would not go up. I have replaced the window clips a couple years ago, with the updated pink clips, the old clips were busted out.
The window controls would not roll the window up, but using the key in the door the window rolled up thankfully. Same thing happens with the passenger window. The passenger window controls will roll the window down but not up.
Any ideas?
Old Feb 14, 2012 | 04:12 PM
Jeffla's Avatar
If you try closing the window using the door switch does it do nothing? or does it goes up maybe 1/2" with each press of the button?
Old Feb 14, 2012 | 04:23 PM
02A6Beau's Avatar
sounds like a switch problem. does your '98 have the "one touch" switches, where it will go all the way up or down without you having to hold the switch?
Old Feb 14, 2012 | 04:36 PM
copper07's Avatar
The door switch will lower the window part way down depending on how long you hold the switch. The switch will also lower the window all the way down it with the one touch feature. Both the driver and passenger window switches lower the window but not raise the window.
Old Feb 14, 2012 | 07:12 PM
hxgaser's Avatar
Probably your driver side master switch went haywire.
Old Feb 15, 2012 | 03:58 PM
copper07's Avatar
In order to swap out the master switch is it the panel with the for buttons in the door or is it a separate part from that?
Audia41990
Feb 7, 2013 12:19 PM
cairo121
Jul 30, 2010 05:57 PM
siddy
Dec 1, 2007 06:10 PM
