Woa Look at my Camshaft!!!!!
Old Dec 3, 2011 | 04:39 PM
Evtechsolutions's Avatar
Default Woa Look at my Camshaft!!!!!
Purchased a car with the thoughts that I would need to do a timing job but look what I discovered on the cam when I pulled off the valve cover!.
look like the lifter is gone and the cam destroyed it while destroying it self as well. I nervouse to replace the cam and lifter only and retime it because I don't know the condition of the valve. Has anyone ever had this happen before and checked the valve. Surely this had to be a defective lifter from the start. THe car still ran and drove just would idle rough and die sometimes but always would recrank and run with epc on after.
Attached Thumbnails Woa Look at my Camshaft!!!!!-2c3df606.jpg   Woa Look at my Camshaft!!!!!-bc697db4.jpg
Old Dec 3, 2011 | 04:59 PM
Srgarrett21's Avatar
Do a compression test, I would think if you have good compression the valve face is fine.
Old Dec 3, 2011 | 05:21 PM
Im not concerned with the valve face more the valve shaft itself if its bent or stuck. I read about a problem known with the "follower" I have always called these a lifter is the follower and the lifter the same thing in another term?
Old Dec 3, 2011 | 07:04 PM
OGBULLYLOCDAWG's Avatar
Is that a 3.0 motor?
If yes, you're not the first or only one to have this happen with that motor.
PM Sent
Old Dec 4, 2011 | 07:55 PM
Yes it's the 3.0 thanks for that pm I read both threads and seems that most people dont have a bent valve problem and they just replace the lifters and the cam. THanks for taking the tiem to show me that. Guess what my wifes gettting for xmas lmao.
dubiousmusic
Nov 17, 2008 06:09 PM
greyA4
Oct 17, 2008 02:04 AM
bubba1
Apr 10, 2006 11:19 AM
bubba1
Apr 9, 2006 07:05 PM
TH12NV
Aug 5, 2005 04:36 AM
