Wobble when braking, only sometimes.
Old Apr 30, 2012 | 12:52 PM
copper07's Avatar
Default Wobble when braking, only sometimes.
1998 A6 Quattro, 30V 178K
I have all new brake pads a rotors on my car and they work great. Over the weekend I started to get some wobble or shuddering when braking at freeway speeds. I don't think it is the pad or rotors as they are fairly new. 3 months on the front, 1 year on the back.
Is part of the steering loose, or part of the suspension? I checked the tie rods and there is no play in the wheel.
Any help would be great.
Old Apr 30, 2012 | 02:24 PM
M5S5's Avatar
Tech Certified
I would have to ask. Where did you get the brake rotors from? Autozone's China's finest? Or were they a good quality German made brake rotor?
Also was the hub cleaned of any rust or debris or were the rotors thrown over the hub without cleaning?
I would start with one or both of those items first.
It is also possible for a brake caliper sticking causing excessive heat , warping the new brake rotors.
Old Apr 30, 2012 | 04:21 PM
badinstincts's Avatar
ohh boy, I still have the wobble when I need to brake harder than an old guy would. I changed rotors (zimmerman) with brakes - slight improvement, but eventually returned to what it was..
Now I just finished all front control arms, front driveshafts, all 4 struts, 4 new michelin tires roadforce balanced and I still have the wobble when I brake hard, and I just had an alignment at the dealership, everything I did, helped with the wobble for a few days but it eventually returned to what it was originally..... UGHHHHH
could it be the wheel bearing inside the "wheel bearing housing"? is there a bearing in there? lol
HELP!
Old May 1, 2012 | 09:29 AM
M5S5's Avatar
Tech Certified
Badinstincs , did you clean off your hub?
Might want to removed the front rotors & dial indicate the the front hubs. Could have a bent hub or rusty crud on it causing the rotor not to ride true.
Old May 1, 2012 | 11:54 AM
copper07's Avatar
I will remove the rotors and check the hub on my car.
Old May 1, 2012 | 05:05 PM
I have not, the problem is I have the bigger calipers and those bolts on the back are hard to get off. Any advice?
Old May 2, 2012 | 08:16 AM
M5S5's Avatar
Tech Certified
More leverage , longer ratchet!
RAE0694
Jul 18, 2012 01:16 PM
badinstincts
May 1, 2012 05:08 PM
redmond1501
Nov 20, 2011 08:33 AM
imaudi5000
B7 Models
10
Mar 7, 2011 09:58 PM
S vier
Apr 16, 2008 11:28 PM
