wont crank
Old Apr 21, 2015 | 01:52 PM
johnnyd33's Avatar
Default wont crank
My a6 wont crank. when I turn the key I hear a hum from the trunk but nothing else. I charged the battery overnight and the charger went to the green light. Tried to start with same result, nothing. The lights come on but not the mmi or radio. No horn. I hooked the charger up to the terminal under the hood and now I get a clicking noise but still no crank. It is a 45 mile tow to a shop. Is there anything I can do to prevent this? If I pull the battery should I take it to a parts store to get tested? Should I only buy an Audi Battery?
Thanks for your help!
Old Apr 22, 2015 | 01:34 PM
sheldon's Avatar
Fast clicking noise is usually the classical sign of a failed battery (or undercharged). Since you charged it over night and get nothing the next morning - the battery probably can't hold a charge. Take it out, get it tested.
Personally I always install a Bosch Battery (OEM) for my Audi's but I've successfully installed Autozone and Walmart batteries in other Audi's without issues (might not last as long or might have less CCA - which could give you issues on very cold days).
Old Apr 23, 2015 | 02:14 PM
johnnyd33's Avatar
Default a6 no crank
Thanks Sheldon! I bought an Autozone battery. It doesn't get real cold here in central south Texas very often, so i hope it will last. I found out I may have to take the car in now to get the computer reset. Well at least it won't have to be towed!
rayo
Sep 19, 2013 10:24 AM
Dylan Cure
Sep 4, 2012 04:21 AM
WintonA4
Nov 28, 2010 01:50 PM
A6fl
Apr 25, 2010 09:52 AM
cschoen7
Sep 21, 2009 07:26 PM
