won't start
Old Jan 10, 2011 | 12:00 AM
purpsticks's Avatar
Unhappy won't start
hey guys.
the other day i went to the store and when i came out and try to start the car it would not catch and start. it does sound like it is spinging from starter and therewas a good battery untill i cranked it so many time it stop turning over. the next day i pulled plugs and was ony gettings spark from 4 and 5 plugs. i ended digging some more online and ended checking cam sensors the rear driver side was cracked so i chaned it, but when i went to check power and ground to sensor i get nothing out of he plugs hot and ground so i grounded the ohm meter and used th power side from the harness and got a reading. also when cranking over i do not see tiing belt or cam gears spining is this normal?
Old Jan 10, 2011 | 02:50 AM
purpsticks's Avatar
oh yeah its a 2.8 all wheel drive auto 2000 a6 it has 143xxx
Old Jan 10, 2011 | 07:25 AM
Jackmup's Avatar
If the engine is cranking then the belt and gears should be spinning.
If they aren't the belt is broken.
However the belt doesn't usually break sitting in a parking lot.
Inspect your belt by hand make sure it is in one piece and attached to the pulleys. If it is broken it will have slack in it.
If the belt is good, Check to see if your getting fuel you may have a faulty fuel pump. Check the fuel pump fuse as well.
Chito
Jun 28, 2010 08:48 PM
mark944turbo
Oct 10, 2005 05:51 PM
