Audi A7 towing option
Towing hook pulls back behind ( inner side of) the rear bumper. It sits there totally out of sight when not used. It is locked/unlocked via a bowden cablen and a **** in the trunk. In Europe we use a 13 pins electrical connector which is fully integrated in the towing hook.
Thanks @Fhod and @quattro617 for the help.
I was a little bit worried using the trailer from U-Haul, plus they look horrible
I did attached that trailer to try it and it felt heavy, the card was ok pulling but not sure if is the quality of the trailer or what, but it didn't feel right.
So I went ahead and purchased an aluminum trailer, expensive but really good, see the picture attached. The Aluma trailer is just 390lbs and fits the Buggy perfectly, in total I'm towing 1040lbs, which the car seems to be pulling without issues at all.
I did attached that trailer to try it and it felt heavy, the card was ok pulling but not sure if is the quality of the trailer or what, but it didn't feel right.So I went ahead and purchased an aluminum trailer, expensive but really good, see the picture attached. The Aluma trailer is just 390lbs and fits the Buggy perfectly, in total I'm towing 1040lbs, which the car seems to be pulling without issues at all.
I love to have of hidden tow bars on my car. Any guide is appreciated.
This type is factory fitted by Audi germany for european a7’s.
Basically it is suitable for diy fitting.
I guess the mounting points are not different for those types. Electronics connections are another question. The control box is connected to the canbus. There might also be a problem with the approval in usa.
Go to https://stealthhitches.com/ they have really awesome solutions. What I particularly like is their ball hitch is rigidly coupled to the hitch unlike a normal ball attachment in a square socket that clunks around as you tow. I used a stealth hitch to tow two seadoos with my V8 S5, and it worked amazingly well! (Although I would not recommend towing with a manual transmission S5 if you value your clutch hahahah)
I have owned this A7 quattro for about 6 years. And drove about 8.000 miles with a heavy caravan during my holidays in Europe. No problems at all, combination was driving very smooth at speeds up to 60 miles per hour (110kmh) on highways and crossing mountain passes with normal traffic speeds.
