Audi A7 Athletic, elegant and dramatic, the Audi A7 is a five-door coupe with the graceful look of a benchmark luxury sedan.
Slow to Start
Old Aug 27, 2013 | 10:57 AM
dsnow's Avatar
Default Slow to Start
Has anyone had a problem with there car not wonting to start? It comes & goes starts right up other time it takes 10 to 15 seconds???
Old Aug 29, 2013 | 09:09 PM
aspen79's Avatar
I would have the fuel pressure leak down checked. By that I mean, how fast does the pressure drop after shutting the engine off. It should hold steady for quite a while. If it drops quickly it means the check valve/fuel pressure regulator in the pump has failed and all the fuel drains back to the tank. Then to start, it has to be pumped all the way back to fuel rails or high pressure pump (depending on year, and if it's MFI or direct injected) and then be pressurized enough to be injected.
If it's a sporadic thing, this may take some time. It'll need a gauge hooked up and monitored through multiple starts until the symptom occurs.
There's not really much else that can cause a long crank time besides that.
Next time it acts up, try cycling the key a couple times first before cranking again and see if it starts better.
PSAS1987
Nov 20, 2012 07:33 AM
audi operator
Jun 21, 2012 05:21 PM
Razan
Sep 26, 2009 04:41 AM
Chicago333
B7 Models
Feb 21, 2008 04:46 PM
ryandlor
Jul 24, 2007 10:07 PM
