05 Audi A8 Battery went dead, just charged and now screen won't open?
Old Jul 18, 2012 | 01:42 PM
costas14's Avatar
Default 05 Audi A8 Battery went dead, just charged and now screen won't open?
Battery went dead I got in the trunk from the ski bag and I charged it up and it runs. Never had a problem but the radio screen won't open anymore. I hit the button but it doesn't make any noises or anything and it doesn't open. What can I do to open the screen? Or what's wrong?
Old Jul 18, 2012 | 03:55 PM
jakematic's Avatar
Does the stereo play at all - meaning just the screen won't pop up ?
I'd clear all DTC's with VCDS (formerly VAG-COM) and see what shows up.
Old Jul 18, 2012 | 05:25 PM
costas14's Avatar
No audio at all. Everything worked on it before the car went dead. Its also the L edition.
Old Jul 18, 2012 | 05:56 PM
jakematic's Avatar
Without scanning it with VCDS there's not much I can tell you unfortunately.
May want to check with a local indie after checking all your fuses.
FYI - Don't pull them out to check! Things get verrrrry unhappy on a vehicle this complex when power starts going up and down.
Old Jul 21, 2012 | 03:34 PM
JETSPEED333's Avatar
SoCal Crew Member
agree on checking fuses
Old Jul 21, 2012 | 05:58 PM
z28pete's Avatar
Audi has a security feature that disables the radio if the power is removed from it. By the battery going dead was the same as disconnecting it. A security code is needed to reactivate the radio. Check the owners manual to see if the initial code is there, otherwise an Audi dealer should be able to help.
ziobello
B7 Models
Apr 6, 2015 09:30 AM
Drklacrosseking
Nov 23, 2007 10:36 AM
