2000 A8L with P1141 code
Old May 21, 2010 | 07:08 PM
YamamanA8's Avatar
Default 2000 A8L with P1141 code
Anybody have any experience with a P1141 code? Anybody know what the most common fix for this is?
Thanks!
Old May 24, 2010 | 05:36 PM
auditech79's Avatar
P1141
Load Calculation Cross Check Range/Performance
Thats a wierd code, have you tried erasing it and see if it comes back? Usually when you get a code like that it either has a bad ECM or bad MAF sensor.
Old May 25, 2010 | 11:22 AM
YamamanA8's Avatar
Yes I reset the code and it came back on. Then it shut off and stayed off for a few days and now it just turned back on, but I haven't checked the code yet to confirm that it is the P1141 code. Will do that tonight. A few people I talked to thought my fuel pump might be starting to go out. What do you think of that? In the mean time I'm going to change the fuel filter and clean my MAF sensor contacts. Anything else I can do to pin point the problem?
Thanks for your reply.
Old May 25, 2010 | 06:52 PM
auditech79's Avatar
Fuel pump? Possibly. Low fuel pressure or a bad fuel pump won't throw a fault code though, if the problem was a lack in fuel, it just wouldn't run, no faults would be stored. The MAF sensor is the highest possibility, and ECM is the next highest. The engine calculates load from the MAF sensor and then the O2 sensors, but if there was a problem with one of the oxygen sensors there would be a fault code, thats because its so well monitored. When a MAF sensor malfunctions (or it isn't within range) it can throw fault codes from load error data, all the way to ABS faults, its tied into everything.
You're on the right track, remove the MAF sensor and use MAF SENSOR CLEANER to get the wire element clean and see what you get.
audiaa6.2000
Jun 30, 2011 11:01 AM
Jackmup
Nov 7, 2009 03:06 AM
Tacoman22
Jul 29, 2009 10:30 AM
98a6
Nov 20, 2007 09:54 PM
