P1141 and 3 bars hot
I got my first 4.2 cel today.
P1141- MAF
and it's running 3 bars hot- coolant temp sensor?
I ordered them both, stinks too I have a Temp sensor for the 3.0 Don't know if it's the same but I guess I need a plastic clip anyway.
P1141- MAF
I was able to replace the temp sensor, wasn't that.
I used a piece of a coat hanger to hold in in place because the clip came out in pieces. It worked out pretty good.
MAF will be here tomorrow- hope it corrects this problem.
Crap!
It all happened at the same time so I thought it might be due to a lean mixture. The stupid thing is surging like mad.
Here's what really happened,
Engineer; Hey I know! Let's bury the thermostat under every damn last thing on the engine so nobody can find it.
Parts sourcer; I'll do one better and source out a 30K cheapo. Then I'll source out a 31K belt, 32K idler, 33K Water pump, 34K...
Mechanic; And I'll replace them under warranty one at a time!
That's the way it went looking at the previous owners records.
I guess it's time to order up that T/B kit
I am just loving life.
All done took a little over 12 Hrs.
I did the T/B rollers and tensioner
water pump, thermostat, serpentine w/ rollers and tensioner. valve cover gaskets, tensioner gaskets, half moon seals.Maf sensor, coolant sensor, replaced a secondary air hose and a bunch of clamps. Fresh coolant and took it for a burn.
I ordered the kits from Blauparts and the tools from ebay ( el paso tool) they both came overnight, for real.The only thing I did not like about the Blau Kit was they changed the water pump to a Saleri with a plastic impeller. I recommend the el paso tool, they are really on the ball.
The old water pump was a leaker. It lasted 50K and had a forged impeller.
Thermostat lasted 40K
From what I can make out the previous owner paid $3200 for a t/b, tensioner, water pump, thermostat and all at separate times. Mean while each time he went in they jacked him up for something else. Poor fella. Cost me $1000 with the tools and FED-EX over night.
Not so bad and it's nice to get that out of the way. That is until I spyed more control arms that need to be replaced.
Screw it they can wait-I'm broke
randomloginname
Dec 30, 2007 02:07 PM
mike_d
May 19, 2006 05:55 PM
