2004 A8 Engine Noise
Old Jun 8, 2007 | 04:52 AM
jimp1954's Avatar
Default 2004 A8 Engine Noise
There is a knocking type noise for 2 -3 sec on cold or warm startup. Audi regional tech supposedly listened to the car and "didn't hear it". My guess is the porter started the car outside, drove it in and once it's started, the noise doesn't repeat unitl it's idle for an hour or more. Is this common issue? Could a high mileage Castrol Syntec solve this issue? There's 51K on the engine. Still under Audi Cert used car warranty. By the way, can you tell where the access to the oil filter element housing is located on this model/yr? Thanks!
Old Jun 8, 2007 | 09:07 AM
techbod's Avatar
Default RE: 2004 A8 Engine Noise
chances are there is crap oil in the car to start with ( 51k ) isnt high its nearly new, put some 05W/30 or mobil 1 0W30-40because the oil needs to me thin on these engines to get round quick
Old Jun 11, 2007 | 01:24 AM
Dubai's Avatar
I had the same problem in my 2004 A8 !
I have tried everthing but after that the dealer found the problem & it was from my Cylinder Heads so it was changed and now the problem is solved.
So in ur side try to flush the oil 2 to 3 times & if the sound was still there, then definetly its from the Heads ..
Old Jun 15, 2007 | 10:42 AM
mya8's Avatar
well all what i know is that my 2006 audi a8l has similar problems like when i start it and turn it off it makes a rumbaling noise to it and that i just got a new oil change by taking it to my local audi dealer i told them the same exact story but they said nothing
I think that maybe when i put the air conditioner on in the car before it gets hot then thats the problem
rplankenhorn
S4
Apr 13, 2015 12:25 PM
kenman
Sep 12, 2012 02:34 PM
tj19855
Dec 31, 2007 03:28 AM
