2005 A8 TPMS Sensor help
Old Apr 24, 2013 | 10:58 AM
Blobb's Avatar
Default 2005 A8 TPMS Sensor help
HELP!!!
Hi gang, I have a 2005 A8 and when I bought the car a little over a year ago the TPMS Sensor batteries were dead. I have been staring at the damn flat tire icon for over a year. I just got some new tires and ordered the TPMS Sensors from OEWheels and had them put in with the tire change. Problem is I bought the 315 MHz sensors instead of the 433 MHz sensors. Is there a way to change the TPMS receiver's frequency to 315 MHz? I don't have VAG-COM so I can't play with it. I really don't want to order a new set of the right sensors to replace the wrong ones. Any advice???
Please advise,
Bob
Old Apr 24, 2013 | 11:44 AM
jakematic's Avatar
Has to be done with VCDS Audi A8 (4E) Tire Pressure Monitoring - Ross-Tech Wiki
Vaguely recall that the receivers may need to be changed as well [could be wrong], but I'd try changing the coding first.
Old Apr 26, 2013 | 01:15 PM
Limoncello's Avatar
changing the coding can change the frequency, ones available can be seen in the link in the prev post
better of swapping them for the correct ones though
more info on tpms here Audi-Resource
Old Apr 26, 2013 | 01:54 PM
Ramialablli's Avatar
I have the same issue with my tire sensors and I suspect it's the batteries. How do you know what sensors to buy at what Mhz?
Old Apr 26, 2013 | 02:52 PM
jakematic's Avatar
US TPMS is usually 433MHz.
Your PR codes [on sticker in book and/or spare tire well] will list them.
Also your VCDS coding will tell you.
Old Apr 27, 2013 | 01:22 PM
Thanks Jake.. I'll check it out
Old May 2, 2013 | 12:47 PM
Blobb's Avatar
Thanks to Everyone!!!
Looks like I need to get hold of VAG-COM to change the Freq...
ogduarte
May 19, 2013 02:17 PM
eazy211187
Aug 6, 2012 07:49 PM
bringamac92
B7 Models
Jun 25, 2011 01:30 PM
Joe Mazza
Dec 13, 2010 12:56 PM
