2007 A8 TPMS Control unit problem / replacement
Old Dec 7, 2011 | 10:40 AM
idfnl's Avatar
Default 2007 A8 TPMS Control unit problem / replacement
Hi everyone,
I will describe the problem I have:
2007 A8
For the last 3 months I have been getting intermittent TPMS errors on the instrument panel (not low pressure alerts) about a system malfunction.
This would come and go occasionally. Last week, I got a low pressure alert that was false, and then the same TPMS fault and now it wont go away, its there the entire time the car is running.
I have tried resetting the pressures but it doesnt work. All 5 wheels show up as blank (no reading) now on the MMI screen.
I am assuming the control unit is dead\dying since it doesnt seem related to any specific wheel.
I am considering replacing it. The part number is 4E0910273A.
Questions, then:
Is there a way for me to verify 100% the unit needs replacement?
Any way I can 'reset' it or try to get it working again without replacement?
If I do have to replace it, this unit lives above the left rear wheel bay, correct? Is this something I can replace on my own without much trouble or can this become an electrical nightmare for me?
If its a job I can in fact do, can anyone give me some instructions on how I should do this correctly?
Old Dec 12, 2011 | 04:02 PM
Gigitty's Avatar
it might not be the TPMS unit but rather the batteries in the sensors in the wheels are dead or dying.
Do you have access to a VCDS? Run an auto-scan and post the results...
I just turned mine off when the batteries died.
Old Dec 12, 2011 | 04:06 PM
idfnl's Avatar
What is VCDS?
Also, the system started to work again, but I continue to get malfunctions. As of now, its an intermittent problem.
If its a battery, wouldnt 1 wheel not report? I am getting blanks on all 5.
Old Dec 12, 2011 | 05:39 PM
jakematic's Avatar
Ross-Tech VCDS aka VAG-COM Ross-Tech: VCDS Tour
Old Dec 13, 2011 | 09:17 AM
Gigitty's Avatar
Originally Posted by idfnl
What is VCDS?
You'll need a VCDS to diagnose...most members are willing to lend you a hand in using theirs. Just have to find someone local and willing.
Old Jan 12, 2019 | 04:32 PM
teds352's Avatar
Default Reinstall TPMS Controller in 2006 Audi A8
I reinstalled the TPMS control module in my 2006 Audi A8 but all I get is the yellow flat tire and blanks on all 5 wheels. It was working perfectly before I removed it from the car. Here is the VCDS results for the TPMS:
Address 65: Tire Pressure Labels: 4E0-910-273.lbl
Part No SW: 4E0 910 273 HW: 4E0 907 273
Component: Reifendruck 2 H01
Revision: 00010028 Serial number: 00000900036711
Coding: 0232125
Shop #: WSC 00000 785 00200
VCID: 5FCDFD8B8E621DB282-800A
1 Fault Found:
00003 - Control Module
000 - - - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 225681 km
Time Indication: 0
Date: 2019.01.06
Time: 16:07:12
Freeze Frame:
Speed: 121.0 km/h
Voltage: 25.50 V
(no units): 0.0
Temperature: 0.0°C
Temperature: 40.0°C
Temperature: 0.0°C
Temperature: 0.0°C
The coding appears to be correct. Do I need an access code to reset it?
Old May 6, 2020 | 12:21 PM
Kyle Pentz's Avatar
Let me know how it goes! I am in a similar situation
Recode Tire Pressure Monitoring Control Module (J502).
If Tire Pressure Monitoring Control Module (J502 ) is replaced, new control module must be coded. To do this, proceed as follows.
  • Connect the Vehicle Diagnosis, Testing, and Information System (VAS 5051A) and select the function test using " Functions/Component selection".
Then
  • "Chassis"
  • "Tire Pressure Monitoring System"
  • "01- On Board Diagnostic (OBD) capable systems"
  • "J502 - Tire Pressure Monitoring Control Module"
  • "Tire Pressure Monitoring functions"
  • "J502 - Code control module"
ItnStln
Apr 12, 2015 10:15 AM
ozis3
May 14, 2009 12:20 AM
oklahoma audi
Jul 27, 2007 05:04 PM
Kurlz11
Oct 7, 2006 11:11 AM
Jorn
Feb 17, 2005 06:00 AM
