A8d2 obd2 lean bank1-2 any advice
Old Jul 30, 2012 | 08:41 PM
A864.2's Avatar
Default A8d2 obd2 lean bank1-2 any advice
. Drive an 2000 A8 facelift short wheelbase anthracite pearl, tinted, lowered eibachs /bilstien sport shocks,19"lemans reps & marigold painted calipers.. Have a lean intake bank1/2 code.is there a definite fix or possible culprit..
Old Jul 30, 2012 | 10:06 PM
02A6Beau's Avatar
there are a couple reasons you could be getting a lean code. are you using a generic OBDII scanner or do you have a VAG specific scanner? either way, posting the exact code or codes can be helpful in narrowing down the problem. a VAG specific scanner is preferable.
Old Jul 31, 2012 | 03:11 AM
A864.2's Avatar
Default Vag needed ?
No vag a CAN OBD2 scanner ill have to pull the codes..all hoses are in good condition and connected.(p1136/1138) codes.it would be nice if i found some1 local that had VAG and didnt mind helpn.
Old Jul 31, 2012 | 10:34 AM
02A6Beau's Avatar
we do have a good collection of Connecticutians(?) around the forums. I suspect you can find someone with vagcom not too far from you. Best guess at this point is that you are having some kind of metering issues. could be the MAF or O2. the next option is a fueling issue FPR or fuel pump or filter.
is the car running like it is having problems? try to clear the codes and see what, if anything comes back. sometimes codes get stored and will still read, even though the problem is resolved.
Old Jul 31, 2012 | 11:58 AM
z28pete's Avatar
^^^ Agreed. Engine is running lean on both banks.
Old Jul 31, 2012 | 07:07 PM
A864.2's Avatar
Thanks and apologize for the delay as Iam new to forums in general..These 2 codes have been with me for well over a year no negative drivability issues.ive cleared them only to have the same 2 every time. December 2011 my Christmas gift to myself was a fuel pump replacement (I almost cried) I figured that was my initiation.I Didnt replace the fuel filter,never got around to it since this was the daily driver.Mass air and O2 sensor never triggered the CEL.I brought it to the same shop who performed the fuel pump work for the lean codes and they wanted to change the IDLE AIR CONTROL directly behind the intake manifold(its covered by the engine cover underneath the four rings) they couldn't guarantee that would solve it.How can I link up with local guys who dose VAG work..
Old Jul 31, 2012 | 08:13 PM
02A6Beau's Avatar
hopefully on of the A8 gurus will chime in. I seem to remember something about a "mechanical flap thing" on the 4.2 where the plastic arms that move the flap are prone to breakage. sounds very much like what the shop said they want to try replacing.
there is a thread on here somewhere that has a list of folks that have a vag-com scanner and are willing to help others out.
daveck2
Sep 24, 2009 05:40 PM
Tirrany2000
Sep 18, 2008 08:27 AM
audiltr
Jul 17, 2008 12:14 AM
vertic
Mar 2, 2008 01:38 AM
mbtbon
Jul 18, 2007 02:46 PM
