Date and time keeps changing. Battery ?
Worth checking...they could reset when below minimum voltage and when disconnected. I'd check the voltage with a meter when cold (after resting..no recent running), before starting...should be above 12V and 13.5-14 when running (alternator input). If battery is taxed below minimum when starting, it may reset clock then(?)
