Engine management light staying on
Old Jan 23, 2010 | 11:01 PM
Eaomoo's Avatar
Smile Engine management light staying on
Hi fellow forum members, only recently (3 weeks ago) purchased a 2002 A8L 4.2, very happy with car, beautiful drive and lots of power and toys to play with . I cleaned the car today and had all the doors open and the radio on after approx an hour the radio shut itself off, I expect the power saver kicked in.
After finished my cleaning I started the car and the engine management light stayed on, the engine runs fine, but very annoying that yellow light on in my dash, drove the car a couple of miles and still light stayed on and has been on every since, any ideas ??? or remedies
Eaomoo
Old Jan 24, 2010 | 12:30 AM
auditech79's Avatar
You mean the check engine light? There are literally thousands of things that can cause a check engine light, mostly emmissions related. If the engine is running fine its probably a bad O2 sensor, faulty EVAP system, SAP system etc. There is no way we can tell you what to do without pulling the fault codes, and to do that you need a scan tool. You can rent one from autozone (usually at no cost) then post the fault code here (ex. P0300) and we can tell you what it is, or look it up here. http://www.bentleypublishers.com/tec....dtc.table.htm
You can also buy a vag com, which is a software you can download to your lap top computer, you just need to buy the cable. http://www.ross-tech.com/
Old Jan 24, 2010 | 02:39 PM
Eaomoo's Avatar
Thanks Auditech 79 much appreciate your comments and answers, will try to obtain the fault codes and post them shortly.
Regards
Eaomoo
Malpas
Nov 5, 2013 04:31 PM
Infinity_UK
Jul 5, 2013 06:26 PM
socialdisorder
Apr 30, 2013 06:24 AM
Ifty1
Oct 11, 2010 10:57 AM
sdsponger
Jun 22, 2009 08:09 PM
