engine runs very rough
Old Jun 20, 2013 | 07:41 PM
josh A8's Avatar
Default engine runs very rough
1999 A8, just started today without warning. sounds like a very bad misfire. VCDS says it's cylinder 4. I changed out the plug and the coil. no difference. swapped the ECM with a good spare. no difference. fault codes are P300 & P304 for the misfires, and the third is a P1690 electrical malfunction relating to the MIL (check engine) light not working. doesn't come on when the key is turned, or after starting. I know it was working before this. I scanned the car about a month ago and it was fine. the car can not be driven over about 20 mph, at which point it shakes violently. I've been through every relay I can find. pulled them and reinserted. nothing makes a difference. all fuses I've checked are ok. this happened one other time. I unhooked the battery for an hour, and it cleared up. that was last fall. it's been a-ok till now. tried the unhook battery deal too. no luck. what would make the MIL light malfunction ?
Old Jun 21, 2013 | 11:12 PM
josh A8's Avatar
changed ignition control module. runs great now. still no MIL light. don't know why...anyone know why there are 2 ICMs ?
Old Sep 24, 2013 | 05:45 PM
chriskapuscinski's Avatar
Not sure, with these cars age and number of connections it could be just a poor connection. Get some connectivity grease in the spots you visit. Also have watch the ECM pins,.. I had some moisture get into my PLETH box and corrode a pin off and the car wouldn't start. By-passed it and the car fired up as if nothing happened.
influentialsonny
Nov 13, 2013 06:30 PM
b1234c
Jun 27, 2013 11:56 AM
andyandjohn
Jul 31, 2012 09:17 PM
Tyrell
Jul 8, 2008 07:30 PM
pumaro
Oct 13, 2004 03:34 PM
