Front Bumper Removal help
Old Sep 7, 2007 | 09:08 PM
ffdsmokeeater's Avatar
Default Front Bumper Removal help
I parked to far over a curb and the bottom of my front bumper cought and popped out of track (the slide in tracks on each side of the bumper). I believe I will have to remove the bumper far enough to re-slide the bumper onto its track. Any help on what/where the bolts are would be very helpful. Thanks
Old Sep 7, 2007 | 09:09 PM
Default RE: Front Bumper Removal help
forgot to add the year is a 1999 A8
Old Sep 10, 2007 | 01:05 AM
auditech79's Avatar
Its pretty much the same as an A6 on that model year, take off the wheels and remove the fender liners, then remove any torx bolts you see behind the fender liner, then you have to pull out the lower grille covers out and remove the two large allan support bolts that go upwards through the bumper beam. Now you should be able to pull the bumper off of the car.
Old Sep 16, 2007 | 12:29 PM
NateNewkirk's Avatar
When you have replaced the front bumper, don't forget to fix the cause. I had the body shop put 5 bolts up through the skid plate to bolts fixed to the inside of the plate above it (which must be removed to change oil, etc). The skid plate is only about 8-9 inches front to rear and it starts just a few inches back from the back end of the front grill.
Another trick --if you ever again feel the car hung up on a curb, have some heavyweight sit on the truck lid while you c-a-r-e-f-u-l-l-y back it off.
boettger1
Sep 14, 2013 09:42 AM
fourringking
Apr 2, 2012 05:41 AM
techbod
Mar 3, 2008 08:43 PM
akielb
Apr 21, 2007 05:39 PM
Slowb5
Jan 13, 2006 02:34 AM
