low humming noise
Old Jan 6, 2009 | 06:51 PM
lenny123's Avatar
Default low humming noise
hi all
i have a 1997 a8 and have lived with this low humming noise that sounds like its the blower
i notice if i turn heater temp to low it stops ?
but turn temp up the slightest its there again
its now getting on my nerves and wondered if any one has any ideas
thanks
Old Jan 6, 2009 | 11:12 PM
auditech79's Avatar
Is it just dependent on the speed of the blower motor, or does it only do it when increasing the heat? Try leaving it on a much cooler setting and manually increasing the blower motor speed and see if it still does it.
Old Jan 7, 2009 | 07:49 PM
lenny123's Avatar
Default low humming
hi
no its not speed sensitive its temp sensitive if i have my heat set at lowest it doesnt make the noise turn it up 1/2 a degree and it starts humming
thanks
Old Jan 8, 2009 | 03:35 PM
auditech79's Avatar
I would say there is a problem with one of the temperature flap motors or something inside the heater duct is moving around etc. In any case, the entire dash board would have to be ripped out to have a look around in the A/C duct work. Its going to be an expensive repair if thats the case, if its a temp flap motor it won't be as bad but still expensive.
Old Jan 9, 2009 | 07:54 PM
lenny123's Avatar
hi
ive had a look and listen under hood today and there seems to be (no idea what they are) two what look like soilenoids and one of them is making the noise
i will try get a picture and post
but thanks for sugestions
Old Jan 10, 2009 | 09:15 PM
auditech79's Avatar
Yeah if its under the hood then it should be easy for me to identify with a pic.
Old Jan 15, 2009 | 10:21 AM
lenny123's Avatar
Default humming noise
hi
ive put a picture in my gallery dont know if link will work but here goes
https://www.audiforums.com/forum/alb...pictureid=3059
see what you can make of that
thanks
Old Jan 15, 2009 | 11:54 PM
auditech79's Avatar
Im not sure what that is, i never had to deal with one before. It looks like its close the fresh air duct so it might control the flap to open and close it. Did you try to remove the filter and see if the fresh air flap opens and closes correctly?
Old Jan 16, 2009 | 02:33 PM
lenny123's Avatar
hi
yes the flap works fine will have to strip down and see what i can find
thanks
Sheasta
Apr 12, 2012 06:58 PM
Schlampah
Jan 27, 2011 08:24 PM
frankinstyn
Feb 29, 2008 07:13 AM
stilldubbin203
Jan 2, 2008 09:23 AM
hyperlight900
Nov 30, 2007 05:37 PM
