Recommended tire pressure for 20" S8 wheels/tires?
Old Aug 6, 2010 | 09:21 AM
Soundchasr's Avatar
Default Recommended tire pressure for 20" S8 wheels/tires?
I put some S8 wheels on my A8 but I don't know what pressure I should use because I don't have the S8 manual. Anyone know the correct pressure?
Thanks!
Old Aug 7, 2010 | 11:42 PM
auditech79's Avatar
Doesn't matter really, whatever the door says is what you should use. Tire pressure is based on vehicle weight, not the tire. Most tires can handle 60+ psi, but no one is about to crank it up that high.
Old Aug 8, 2010 | 10:20 AM
silverd2's Avatar
I have 2 sets of wheels for my A8...17 & 18"...the label on the inside of the gas lid (like on your 2000, I assume) says 30lbs for 17" and 32lbs for 18". My last Porsche had similar recommended differences.
I would NOT assume a rule of 2 extra pounds for each extra inch of rim though. Different aspect ratio and width combinations determine how a tire "spreads" on the road under the same weight...not the rim diameter.
In racing and serious exotics circles, they often decide perfect pressure with a pyrometer (tire thermometer)...uniform temperature across the whole tread section after a calm straight road drive, without hard acceleration. Hotter in the middle = too much pressure...Cooler in the middle = too little.
So, I would try to contact someone with an S8 model that offered the 20" option (same aspect ratio/width)...or a dealer. They might even have one on the lot.
Old Aug 8, 2010 | 03:36 PM
Soundchasr's Avatar
My book says says this:
255/40 R19 AllSeason Front-36 Rear-38
255/40 R19 HighPerformance Front -33 Rear -35
275/35 R19 HighPerformance Front - 33 Rear - 36
I have 265/35ZR -20.
Guess I gotta call the dealer. I hope their in a good mood this time....
Old Aug 8, 2010 | 03:58 PM
silverd2's Avatar
Yep, depending on your normal load too.
I've always gotten good even tire wear, goin with the Audi label's small load suggestion...front and rear the same. I rarely ever carry much more than 1 passenger and a set of golf clubs.
Don't know what they recommend for 20's and load size, though.
kpatz
Oct 6, 2018 01:45 PM
jo2valdez
Jul 24, 2010 08:15 AM
hunterln
Nov 3, 2009 03:05 AM
Flarika
May 28, 2007 06:31 PM
mischiru
Jul 29, 2006 10:05 AM
