Audi Q5 The Audi Q5, aerodynamics have never looked so good.
Q5 pulling to right
Old Sep 29, 2012 | 03:55 PM
SMq5's Avatar
Default Q5 pulling to right
I have a 2010 Q5 S-line with 50k miles on it. I just replaced the tires (for the second time since the original set). I went with a Continental DWS given positive reviews from a family member with a Cayenne. Immediately upon leaving the tire store, I noticed that my car was pulling to the right. I tested this on streets, highway, etc at different speeds and got the same result --- if I let go of the wheel I veer into the right lane pretty quickly.
They rotated the front two tires, and it still pulled to the right. They ordered two more new front tires, and it still pulled to the right. They rotated the tires front to back, still pulls. An alignment check indicated everything is within specs. What gives???
Old Sep 30, 2012 | 12:28 AM
z28pete's Avatar
Make sure if the tires are diractional they were mounted properly, make sure the brakes are not dragging on one side, and then take the car to a good alignment shop. They should be able to raod test the car and fix the problem. You could always go back to Audi if the warranty is still good.
Old Oct 4, 2012 | 11:25 AM
AudiQ52012's Avatar
when you let go of the steering wheel while the car slowly moves to the right does the steering wheel stay straight or does it have an angle?
Dantheman
Feb 18, 2012 11:44 PM
747guy
Sep 2, 2010 08:40 AM
warranty225cpe
Oct 30, 2008 10:53 PM
yesss4
Oct 23, 2008 02:29 AM
XrichTHEdudeX
Jan 10, 2007 02:46 AM
