Audi Q7 The Audi Q7, beauty on and off the streets. Refined styling paired with power and advanced technology.
fuse box location
Old Jul 26, 2010 | 10:56 AM
attyq7's Avatar
Default fuse box location
hi can someone please tell me where the fuse box is located ?? my cig lighter and the 12v sockets are not working and i have been searching high and low for the fuse box ,(no i dont have a owners manual in case you are wondering ) ,i am hopingit will be a blown fuse and nothing else thanks atty
Old Jul 26, 2010 | 11:18 PM
aspen79's Avatar
There's actually 5 fuse panels. One under the left cowl panel, one on each end of the instrument panel, one on top of the battery under the drivers seat and one more in the right side of the luggage area behind the access trim panel. I'm pretty sure the fuse you are looking for is in the left instrument panel box.
Open the door and on the very end of the panel you will see a trim cover. There's a notch along the edge of it. Use a small screwdriver and pry out and it'll pop off. It's held by 3 or 4 spring clips. It should be a 20 amp fuse, can't say which position number it is though.
Old Aug 7, 2014 | 10:34 PM
Qbert's Avatar
I am having the same issue in my 2008 Q7, 12v sockets in rear don't work. Did changing out the fuse fix the problem?
Old Sep 18, 2018 | 12:12 PM
frey's Avatar
Hello, exactly same problem here (2014 Q7). Looks like 12v socket is not working. Therefore, I can't locate fuse My friend told me, that fuse box is similar to Q5, but I replaced fuse no. 4 in panel C (I was using this diagram, maybe is not correct?) and socket is still not working. Appreciate any help!
bodger
Dec 5, 2014 04:49 PM
SUPERMARIO680
Jan 23, 2014 12:12 PM
Dan1969
Jul 7, 2009 11:13 PM
lespaul2510
May 24, 2009 11:43 AM
rwm1370
Aug 18, 2005 05:20 AM
