Audi Q7 The Audi Q7, beauty on and off the streets. Refined styling paired with power and advanced technology.
Multiple mis-fire codes on 2007 4.2
Old Jan 1, 2016 | 11:25 PM
titan2782's Avatar
Default Multiple mis-fire codes on 2007 4.2
I'm helping my father-in-law with some issues he is having on his 2007 Q7 4.2 P0300, P0301, P0302, P0308 and other mis-fire codes. He ended up buying a new coil pack (only 1) but once he told me what was going on, I pulled the codes and determined it's most likely a plug issue, not a coil issue.
I pulled the plugs and they were NGK laser platinum plugs but I couldn't tell if they were a 5547 or 5592. The plugs looked very fouled, like it's running fat, but there wasn't any carbon build up, it just looked like it wasn't getting hot enough so I'm thinking that whoever put those plugs in (it was bought used), used the NGK 5592 which is a step colder than the 5547.
I ended up putting in some AC Delco double platinum plugs with single a electrode gapped at 0.035 (NGK's were not available) to get it going again as I believe that the plugs were the issue. But, I don't know anything about Audi, so is it common for the coil packs to go out and cause a mis-fire? Is there something further up the line to check? I saw a blip about a PCM update to fix mis-fire issues, but didn't look into it.
Old Jan 9, 2016 | 08:36 PM
flat12's Avatar
Coil Packs are a known issue, and often there are campaigns to replace them, not sure if the Q7 is included but I know that many other VW models are.
Old Jan 13, 2016 | 01:55 AM
rockingjohncarter's Avatar
Yes dear. Coil packs are a known issue.
irunktm
Jul 25, 2012 09:37 PM
amiller86
Mar 29, 2008 06:33 PM
ezlnh8u
Oct 16, 2007 01:45 PM
Scotts
May 13, 2006 12:35 PM
