Audi Q7 The Audi Q7, beauty on and off the streets. Refined styling paired with power and advanced technology.
Q7 2015 295/40/r21 ok ?
Old 02-05-2016, 12:05 AM
thekochs's Avatar
Default Q7 2015 295/40/r21 ok ?
I have 2015 Q7 came with 295/35/R21 Pirelli P-Zero and after 15K miles time for new tires. Going with Continental ExtremeContact DWS06 but would like to get more sidewall height so was thinking 295/40/R21. The "40" is not listed as OEM but Conti makes them. Sure is plenty room in rear wheel well but not 100% sure about turning/etc. in front. Has anyone put 295/40/R21 on their Q7 ? I've done tons of Googling searches and not clear the results.
Note, my Q7 does not have the adjustable air ride option settings.
Old 02-07-2016, 08:41 PM
flat12's Avatar
With a series tire the sidewall height goes from 4.06" to 4.65", and the overall diameter goes from 29.13" to 30.29". Take a look at your front
suspension above the tire, you will see a bolt that is fairly close to the inner sidewall of the front tires. If there is room for an additional 0.59" sidewall height, then I do not think you'll have any issues with the taller tires.
Old 02-09-2016, 04:32 PM
thekochs's Avatar
Got my 295 / 40 R21 Continetal ExtremeContact DWS06 on my 2015 Q7.
I put thru a lot of turning and up/down hill tests and is fine. No rubbing. Looks awesome !!! The Conti's have really nice ride. The 40s give a real meaty/beastie look over the 35s.
Attached Thumbnails Q7 2015 295/40/r21 ok ?-2016-02-09_181115.jpg
Old 02-09-2016, 09:54 PM
SpeedMan's Avatar
Getting the Continental tires sure is a good choice. The 40's has 5% higher sidewall compared to 35's.
Old 02-10-2016, 06:23 AM
thekochs's Avatar
I had worried about them "fitting"....ie, rubbing with the extra height. Rear wheel wells of course no concern. The issue/concern was the front wells as you turned in or out sharply, plus compression of struts/shocks. The installers checked (we had 35s on standby) and I was in garage when they installed and looked myself. They road tested.....and I did as well putting it thru forward and backward hard turns and up/down a VERY steep driveway...basically worst case scenarios......I found no issues. However, my caveat is that this is a MY2015 Q7 & it does not have the adjustable air ride feature. Thus, not sure for those other folks considering doing this that may have different MY/etc....but wanted to post this result.
Also, I had friend who is part of large national tire wholesaler and he said/confirmed that the Conti new ExtremeContact DWS06 tires are really great product. I have not had extensive driving yet but as "new" tires both on aux streets and highway (I did test at up to 70mph) they road great. I will say the Pirelli P-Zero is perhaps slightly better ride but with them wearing out at ~15K miles, versus the DWS06 having 50K mile tread warranty, it was no brainer choice. Maybe other folks can afford $1300+ a year for tires but not me. Anyway, for those considering on size concerns and ride the DWS06s seem great ride and DO fit Q7.
Old 07-12-2016, 05:41 PM
Joshua Rich's Avatar
Still no issues with this size? Thinking about doing the same to mine soon as it appears to be tire time!
Old 07-12-2016, 09:07 PM
thekochs's Avatar
They have been awesome !!!!
No issues, no rubbing, good ride, great price compared to Pirelli...and no brainer on decent tire mileage wear vs. Pirelli.
Old 07-15-2016, 10:08 PM
That's great! I hate to be a burden, but could you post your ride with those tires from different angles. You're the only one I've seen do this, so just want to get a good idea of how it's going look on mine before I pull the trigger! Thanks in advance
Old 07-15-2016, 10:19 PM
thekochs's Avatar
They look awesome....beefy, wide, nice looking tire....complements the car's lines well. I had to take in garage....at night now here. Hope this helps.
Continental ExtremeContact DWS06 295 / 40 R21
Attached Thumbnails Q7 2015 295/40/r21 ok ?-q7-1.jpg   Q7 2015 295/40/r21 ok ?-q7-2.jpg   Q7 2015 295/40/r21 ok ?-q7-3.jpg
Old 07-15-2016, 10:23 PM
thekochs's Avatar
Here is the pic from thumbnail above......taken day I had them put on.
Wanted to post since that pic was during day time.
Attached Thumbnails Q7 2015 295/40/r21 ok ?-q7-4.jpg
Quick Reply: Q7 2015 295/40/r21 ok ?
