Q7 wet footwell (driver side) UK
Hi there ,
Over the past 3-4 weeks I have noticed the footwell in my 7 has become saturated ?? I put it down to the snow we have had and the melt from getting in and out of the car , after drying the mats and carpet the problem appeared to have disappeared until I washed the car on Saturday and guess what ?? the leak is back !!!!
Has anybody got any clues ????? Im worried the electronics under the drivers seat may become soaked !!!
I was driving through a lot of wet snow and slush a couple days ago.. anyway yesterday I decided to clean the rubber mats, when i removed the drivers mat the carpet was completely soaked under the mat. I going to keep my eye on that..
Hi Keithmas,
I had the same problem last spring. I was in a heavy rain storm and water started coming in to the passenger foot well (Q7 U.S. version but same side as your UK version). I called the dealership and they were able to fix the problem quickly. Essentially, the water collection tray from the drain on the windshield was overflowing because it was clogged with tree debris (leaves, gunk, etc.). I park on the street, so they had to clean out the drain and it has worked flawlessly since. You might be facing a similar issue, so give the dealership a call. Hope that helps!
Hi there ,
Also, if you have a panoramic sunroof/moonroof, the drain holes can get blocked, and water enters into the footwell due to a leak from a join in the drain pipes which run down the A-pillars.
You can remove the wheels and undo screws that hold the wheel arch cover. This allows the cover to be pulled away from the body in the wheel well where you can see a black rubber drain outlet. This can be pulled off and debris removed from the the hole which stops water from draining out.
You can then get a hose and hold it over the sunroof to flush the drains.
This problem is very well known and may cause catastrophic problems you can search www.audiworld.com for this
k00061804
Jul 25, 2012 04:09 AM
slideitsidewayz
Nov 23, 2008 05:32 PM
slideitsidewayz
Nov 23, 2008 05:31 PM
Rayman740
Feb 8, 2007 06:12 AM
