17hg vac at idle - is that about normal for a 180q?
well i cant see how your not feeling a "pull" through low rpms... once you get above about 4k rpms it will start to slow down pace through the rpm range.. unless you have a chip, if you had a chip youd feel a solid pull through the rpm range... OR - a diode / mbc to up the boost a little... that would be like following cincys shoes his ole "20psi without a chip" (
cincy)
So long story short, im pretty sure your TT is running how it should and you just arent as satisfied as you may be hoping for... my bet is that after a chip or diode/mbc install you would instantly have a smirk on your face like the grinch on christmas eve...
cincy)So long story short, im pretty sure your TT is running how it should and you just arent as satisfied as you may be hoping for... my bet is that after a chip or diode/mbc install you would instantly have a smirk on your face like the grinch on christmas eve...
18-22in hg is normal, it depends on sea level. You can give a once over but you seem about normal. When you drop to 15in hg, does your rpms go up? If so that is normal also.
yes every 3-4 seconds it drops to 15 and the rpm's go up. well, im not pulling any codes at all. something just doesnt feel right. though. i guess ill start saving up for a trip to the stealership.i was hoping it would be something as simple as a vacuum leak.
ill look at my coolant sensor after work. my maf is clean - i had it out yesterday and its about 1 month old. my sensor... who knows how old that is.
