2002 audi tt overheating replaced cooling fan and tstat
Old Jun 26, 2013 | 01:19 AM
ZayaAlb's Avatar
Default 2002 audi tt overheating replaced cooling fan and tstat
So noticed my cooling fan crapped out replaced it, started working got happy now still overheating... so mechanic tells me thermostat... replace that still overheating.... no answer on the web and this sucks ***** tried these someone help!!!!!
Old Jun 30, 2013 | 11:50 AM
Clrwatrtom's Avatar
it's water pump time my friend. Do the timing belt and tb tensioner while you're in there. The water pumps have plastic impellers and over time, the many heat cycles on the pump will degrade the impeller and when the car gets up to temp, the impeller expands faster that the pump shaft which is made of steel causing the impeller to freewheel in the shaft. i would use a water pump with a steel impeller.
savantv
Feb 1, 2012 10:32 AM
umaxjoe
Mar 11, 2010 07:26 PM
rkmA4
May 25, 2009 07:29 PM
fireman9585
Jan 17, 2009 09:55 AM
