about to change the brakes
Old Jun 30, 2008 | 04:43 PM
ltsheets's Avatar
Default about to change the brakes
I have a day off this thurs and I know my rear brakes need changing. I have a copy of the Bentley service manual to help me but just wanted to ask those who had done a rear brake pad change how hard it is to do?
Old Jun 30, 2008 | 06:16 PM
ouTTie914's Avatar
Default RE: about to change the brakes
I hope your rotors are in good shape. Don't want to put new pads on grooved rotors.
All together it's not a difficult job, as long as you have the proper tools!
Like a rear piston caliper tool. You have to spin and push at the same time for the rear piston to move.
Local auto part store should carry it; if not Sears definitely does.
Oh you might also consider a can of brake quiet.
It just gets sprayed onto the back of the pads, and helps prevent squeaking and/or squealing.
Old Jun 30, 2008 | 06:22 PM
achTTung's Avatar
brakes arent hard. just remember, the pistons in the rear brakes need to be rotated as they're compressed. ECS sells a caliper retraction kit, if you wanna get fancy about it, but you could probably make due with a C-clamp and a screwdriver or somethin.
Old Jun 30, 2008 | 06:23 PM
achTTung's Avatar
oh, and loosen your brake reservoir cap so the fluid has someplace to push to easily while you retract the piston.
Old Jun 30, 2008 | 06:38 PM
jakej's Avatar
yeah, what they said. You need the tool, but it's an easy job.
Old Jun 30, 2008 | 10:54 PM
ltsheets's Avatar
well i figure that the auto shop on base should have all the tools i need so sounds like it shouldn't be too bad thanks for the heads up
thuggins
Aug 24, 2010 07:50 PM
v diaz
Mar 20, 2009 02:39 PM
readimag
May 7, 2008 01:39 AM
popsinc
Jan 6, 2008 02:55 PM
phj222
Nov 17, 2006 11:14 AM
