advantage of having the N75 & MBC in Parallel
Old Jul 18, 2007 | 06:20 PM
auditt225's Avatar
Default advantage of having the N75 & MBC in Parallel
What is the advantage of having the N75 & MBC in Parallel ?
Old Jul 18, 2007 | 06:25 PM
cincyTT's Avatar
I'm make believe
Default RE: advantage of having the N75 & MBC in Parallel
if you use a ball and spring mbc it will be smoother.If you just use a bleed/gatedmbc (no n75) on a stock turbo you will be plenty smooth and wont have a huge spikes.
Old Jul 18, 2007 | 07:37 PM
auditt225's Avatar
Thanks cincy I just did it and its a lot smoother now. How am I able to raise it to 22psi with the n75 and mbc? If I can?
kchao2000
Apr 19, 2010 09:48 PM
syxxty
Aug 15, 2008 07:23 AM
TK_Fulgore
May 29, 2008 01:31 PM
B5luver
May 14, 2007 12:08 AM
