Audi TT 2001 - HELP!
Old Mar 12, 2011 | 03:40 PM
auditt0323's Avatar
Exclamation Audi TT 2001 - HELP!
I have a used, manual Audi TT 2001. I got it in August, and it now has about 77,000 miles on it. It has had a recent oil change, the timing belt was replaced recently before I purchased it, and the CarFax on it were normal.
I have recently had an issue with the car, however..
When I start the car, it fluctuates between the lowest RPMs (between 0-10), and the temperature is all way the down to cold. I can feel the car sort of..lurching back and forth as I try to drive and switch into first gear. Once, it even shut off.
This happened a few times, but it was eventually fine by the time I got it going.
However - I noticed it starting to have some problems even up at higher speeds.
Does anyone have ANY tips whatsoever? The check engine light also came on. I would greatly appreciate any and all suggestions here.
Old Mar 12, 2011 | 05:08 PM
TTQ2K2's Avatar
Zip over to your local autozone and have them scan it (they do it for free) and print out the codes. then, check here for code breakdown.
http://wiki.ross-tech.com/wiki/index...ry:Fault_Codes
It may be something as simple as needing coilpacks.
cheers.
Old Mar 13, 2011 | 01:39 AM
auditt0323's Avatar
Thank you!
Wtftylor
Nov 1, 2012 01:01 PM
nukauto
Feb 2, 2008 11:02 PM
Jorgen
Aug 7, 2006 11:29 AM
Bit646
May 11, 2006 05:24 AM
