Audi TT Engine Smoking Issue
Old Mar 18, 2010 | 11:53 PM
Joelt133's Avatar
Default Audi TT Engine Smoking Issue
Hi, I recently purchased a used 2000 Audi TT and noticed that after driving for about 5 - 10 minutes light smoke was rising up from the engine and there was a pretty heavy burning smell with it, and I haven't driven it again since. The coolant and oil seem to be fine, so I'm wondering if there's any other likely cause of this? Any help would be really appreciated.
Old Mar 19, 2010 | 10:41 AM
cincyTT's Avatar
I'm make believe
most likely a leaky valve cover gasket. Pull off the engine cover and look around. It if its, its a simple job that takes about an hour for a first time and runs about $40 in parts
Old Mar 19, 2010 | 11:55 AM
ilackav8's Avatar
did you peak around at anything while it was running? my a4 had a similar issue and it was the cat. it was kind of glowing red because it was clogged from malfunctioning coil packs.its worth a shot anyway
Old Mar 19, 2010 | 01:30 PM
Joelt133's Avatar
Cool, thanks for the suggestions. I'll check into both of them.
JorgenA4
Aug 6, 2009 12:22 PM
turboAUDI77
Apr 25, 2007 12:44 AM
robmas
Apr 23, 2007 06:00 PM
EvilA4
Jan 11, 2006 01:04 PM
josephrsalexander
Nov 26, 2005 10:57 AM
