Baseline 225 Dyno run
Soon...
I plan on having the clutch done, and the uni chip in the beginning of next month.
The only one that gave any kind of #'s he eased into so it wouldn't slip.
Even on my 95.4 hp run it made more torque than the s2000's there.
Finally compiled data from a vag-com 'on road' dyno run, Hp came out pretty damn close to that!
I'm in VT now, don't have my own place yet, kinda bumming on my buddys couch. Once I'm sorta set, I'll try to get my graph posted up.
You are correct sir.
Dynojet, and that was easing into the run so the clutch wouldn't slip as bad. I think the HP was about right, but I suspect the actual torque wasa good bithigher.
ORIGINAL: Skipponator
My hunch says dynojet...... [8D]
ORIGINAL: rayveedub
190 with a slipping clutch......pretty good. what kind of dyno?
What disc? Not stock also right?
ORIGINAL: cincyTT
A stock clutch can easily. If you can get just a nice disc with it and keep the stock pressure plate, do that.
ORIGINAL: WishIWasRWD
ORIGINAL: cincyTT
You tq would be higher since you didnt give it full gas down low
