Baseline 225 Dyno run
Old Jan 28, 2008 | 03:36 PM
cincyTT's Avatar
I'm make believe
Default RE: Baseline 225 Dyno run
So...ahhh.... when is the clutch going in? those dynos look awful.
Old Jan 28, 2008 | 05:28 PM
WishIWasRWD's Avatar
Soon...
I plan on having the clutch done, and the uni chip in the beginning of next month.
The only one that gave any kind of #'s he eased into so it wouldn't slip.
Even on my 95.4 hp run it made more torque than the s2000's there.
Old Jan 28, 2008 | 05:29 PM
Think fast:
Cheapest stock feeling clutch that will hold up to bolt-ons, no BT.
Old Jan 28, 2008 | 10:22 PM
cincyTT's Avatar
I'm make believe
A stock clutch can easily. If you can get just a nice disc with it and keep the stock pressure plate, do that.
Old Jan 28, 2008 | 11:00 PM
achTTung's Avatar
Finally compiled data from a vag-com 'on road' dyno run, Hp came out pretty damn close to that!
I'm in VT now, don't have my own place yet, kinda bumming on my buddys couch. Once I'm sorta set, I'll try to get my graph posted up.
Old Jan 29, 2008 | 01:26 AM
rayveedub's Avatar
190 with a slipping clutch......pretty good. what kind of dyno?
Old Jan 29, 2008 | 02:52 AM
Skipponator's Avatar
ORIGINAL: rayveedub
My hunch says dynojet...... [8D]
Old Jan 29, 2008 | 10:02 AM
  #18
You are correct sir.
Dynojet, and that was easing into the run so the clutch wouldn't slip as bad. I think the HP was about right, but I suspect the actual torque wasa good bithigher.
ORIGINAL: Skipponator
ORIGINAL: rayveedub
Old Jan 29, 2008 | 10:06 AM
  #19
What disc? Not stock also right?
ORIGINAL: cincyTT
Old Jan 29, 2008 | 02:59 PM
  #20
cincyTT's Avatar
I'm make believe
ORIGINAL: WishIWasRWD
ORIGINAL: cincyTT
all stock would hold the basic bolt ons. A stg1 would be a nice upgrade and would hold it better.
You tq would be higher since you didnt give it full gas down low
RG006
B8 Models
Jan 1, 2009 10:28 AM
pfeifstudd
Sep 25, 2007 04:19 PM
gooseo3o3
Jun 30, 2007 02:17 PM
ROCKET_S4
Nov 23, 2005 06:02 AM
Riddler
Jul 14, 2005 10:48 PM
