Battery Light question.
Old Feb 15, 2016 | 05:34 PM
ericcota2003's Avatar
Default Battery Light question.
Hey all,
Just a quick question that I'm sure someone has seen or experienced at some point. A few weeks ago I started the car to warm up...in Vermont so its cold out there. After the car started to warm up in temps I revved the car up (no reason as to why I did that...just wanted to hear my exhaust I guess) When the car reached about 4k rpms the battery light came on and the car seemed to hesitate slightly. I let off the gas and the engine made a quick stutter then ran normally with the light going off. After a few times of repeating this I started checking connections and what not. After a couple weeks I thought that maybe my accessory belt was getting loose and had a tbelt job done including that belt. I thought everything was good to go and everything was great for a couple weeks.
Yesterday I was getting on the interstate and decided to really push it due to a short on ramp and crazy traffic. I hit 5th gear and the battery light came on. I looked down and let the car just coast with the clutch still engaged. Yes I was going at a slightly excessive speed lol. After about 45 seconds I shifted into 6th gear and the light went out. I would normally guess alternator/battery but they are both within 2 years old and the car runs normal and the battery seems to charge properly. I don't have an issue with starting the car or normal driving. It seems that it's just when I rev it up past the 4k mark that I see that symptom.
Other than that I am happy to say I passed the 250k mile mark a couple months ago and the car still runs amazingly (besides this of course)
Thanks for the help.
Eric
Old Mar 2, 2016 | 06:00 PM
markymarc's Avatar
Eric,
I'm going to say this to you, as long as you have your radio code, do what I would do on every other car, start the car, disconnect the battery, if it dies, it's your alternator most likely.
I put a new alternator in my Son's van a year ago, he had the same issue you did (mind you it's a GM), it even died on the side of the road a few times, but when he wiggled the ALT connections it fired up, I had the same thought as you, it's ONLY a year old...so I pulled it out, went to Autozone, alternator tested fine...but I figured what the hell, bought a new one....installed it....guess what, it's been running fine ever since....kind of odd, but that's my .02, always keep it simple.....at a certain RPM threshold, you are pushing more amps into your alternator......I'm going to guess, it probably could be your Alternator.....
blu.suede
S4
Apr 21, 2015 12:38 PM
