boost controller and FPR?
Old Jul 27, 2007 | 12:17 AM
zero388's Avatar
Default boost controller and FPR?
If I got a boost controller would I need a new FPR? I dont really understand many things concerning boost so this is probably a dumb question. thanks for the help
Old Jul 27, 2007 | 12:19 AM
cincyTT's Avatar
I'm make believe
Default RE: boost controller and FPR?
easy answer NO, but if you dont have a chip, you cant/shouldnt up the boost.
Old Jul 27, 2007 | 12:23 AM
andrei's Avatar
cincy... since you are here, ifI do the diode mod instead of the chip, andI get a 4 bar FPR with it, and swap it with the stock3bar,canI take the boost higher than initially recommended in your little write up?
If yes how muchhigher?...
Old Jul 27, 2007 | 12:27 AM
cincyTT's Avatar
I'm make believe
I dont know anyone that has tried it on a 225 before. Not sure how it would work. I would reserve the test mule to someone else or give it more time before you attempt it.
Old Jul 27, 2007 | 12:38 AM
andrei's Avatar
so nobody that you know with a 225 has the diode mod? or nobody tried higher boost with the 4 bar FPR?
Old Jul 27, 2007 | 01:02 AM
cincyTT's Avatar
I'm make believe
no one with a 225 has tried a diode mod.
Old Jul 27, 2007 | 01:11 AM
andrei's Avatar
shouldI be the first one?.... if you get 20psi on the mk03... what do YOU think I should aim for on my stock mk04 with the 4bar FPR?... what's the max?
Old Jul 27, 2007 | 01:22 AM
cincyTT's Avatar
I'm make believe
20psi will be fine, its you controlling boost that worries me. You might get a CEL (if not limp) because you just pinned your ecu to seeing 11psi and thats below requested. Thats my beef. Dont really think it can be done unless a 4.4v diode exist. That MAY work.
Old Jul 27, 2007 | 01:25 AM
cincyTT's Avatar
I'm make believe
did a search, dont think they exist. You can look more for a 4.4v zener diode if you like
Old Jul 27, 2007 | 01:54 AM
andrei's Avatar
then shouldn't itbe mentioned that the diode mod is not for 225's? since there's no DIODE for us?
just a thought. It is still an awesome mod (performance/money) even thoughI won't get to do it on my beautiful car.
thanks a lot for all your feedback cincy.
<is that ur name?or that's just ur city?>
