boost question
If you overboost into limp mode, you will get a "17963 P1555 Charge Pressure Upper Limit exceeded"
If you don't get that code stored, you've likely got another problem. Bad DV, boost leak, etc.
Yes, a bad DV will not hold boost causing a premature dump and drop in pressure. Normally they are accompanied by a "honking" noise. Either pick up another stock DV, an aftermarket one, or flip your's over to see if reversing the pressure on the diaphram helps.
