boost question
Old Mar 21, 2007 | 12:31 PM
XCLR8TT's Avatar
Default RE: boost question
If you overboost into limp mode, you will get a "17963 P1555 Charge Pressure Upper Limit exceeded"
If you don't get that code stored, you've likely got another problem. Bad DV, boost leak, etc.
Old Mar 21, 2007 | 12:54 PM
spyderconv1999's Avatar
It allways seemed to hold boost before, but now it seems slow to boost and drops off way more than i remember..... would the DV do this?
Old Mar 21, 2007 | 12:58 PM
XCLR8TT's Avatar
Yes, a bad DV will not hold boost causing a premature dump and drop in pressure. Normally they are accompanied by a "honking" noise. Either pick up another stock DV, an aftermarket one, or flip your's over to see if reversing the pressure on the diaphram helps.
Old Mar 21, 2007 | 01:03 PM
ok thanks man, oh yea i did notice that also when it boosts and falls off it sometimes picks back up.....like 14lbs to 9lbs to 12lbs to 10lbs kinda up and down
Old Mar 21, 2007 | 01:58 PM
bump
Old Mar 21, 2007 | 04:22 PM
Default RE: boost question BAD DV?????
could i have a bad DV?
Old Mar 21, 2007 | 04:52 PM
XCLR8TT's Avatar
Yes you could, just as I said above, there are a number of reasons for losing boost or boost fluctuating.
oooos4
Sep 6, 2014 11:28 PM
TTsteve
Oct 12, 2007 04:30 PM
TurboToughTT
Jul 28, 2007 10:49 PM
JohnnyBravoA4
Jan 2, 2007 05:02 PM
02tq
May 25, 2006 02:21 PM
