Brakes installed [pictures]
As an interim until I can get a BBK, I decided to go with PowerSlot cryo slotted rotors and RedStuff pads.
... and with the wheel on...
I have the green caliper paint kit too... but I think that'll require more time than the hour it took me to change rotors and pads.
do those pads have the wear sensor on them? I made the mistake of keeping the stock pads when I did the drilled/slotted brakes on mine and they have worn the pads down to almost nothing... so I will have to do them again and need to find a good aftermarket pad that still has the sensors in them.
ORIGINAL: eliTTe
that's all the sensor is, a copper wire in the pad that breaks if the pad is worn.
Yea... they have the sensor in them. [only the front left has the sensor].
the only hang up is getting the rotor off. mine were seized up on there. I used a mallet to get them off once the calipers and alignment screw were out.
scotts custom
Jan 18, 2008 11:25 AM
JaceTun
Aug 15, 2007 05:46 PM
Audi_Skydiver
Jun 1, 2007 10:58 AM
neur0tic
May 22, 2007 01:11 AM
