CAMS
Old Apr 24, 2008 | 09:49 PM
01TT225's Avatar
Default CAMS
i am looking for cams for my audi TT 225 i found some from Eurospec Sport i want to know what duration would be sutable because i dont want to install them and the car doesnt work i foun 210 250 and 268 duration all with a 110 lobe center can anyone help out with the subject i just want to know about it so please no arguments
thanks
Rich
Old Apr 24, 2008 | 10:01 PM
exTTreme's Avatar
Default RE: CAMS
This link might help you it kinda explains what it does off to the right of the specs Clickhope that helps you
Old Apr 24, 2008 | 10:08 PM
Wintermute's Avatar
Default RE: CAMS
He's a '01 that's non-vvt.
Old Apr 24, 2008 | 10:10 PM
exTTreme's Avatar
Default RE: CAMS
As am I (am I missing something)?
HYDR: sport Excellent grind offering good power throughout the midrange. No VVT
from that description I would think it works on non-VVT engines and is not meant for the engines with VVT
Old Apr 24, 2008 | 10:51 PM
cincyTT's Avatar
I'm make believe
Default RE: CAMS
If you are not running something making 350whp or more, you dont need cams and are wasting money. If you want cams, Cat Cams make the best. If you are planning to put these on a stock turbo, this isnt an Evo.
Old Apr 25, 2008 | 04:29 PM
achTTung's Avatar
Default RE: CAMS
Cams are a big deal on N/A engines, not so worth it on forced induction until you start to run out of other mod options. But you didn't want any arguments,so have at it.
Old Apr 26, 2008 | 02:20 PM
rayveedub's Avatar
Default RE: CAMS
cat cams are the best option we have for 1.8t's. but there is a problem with the gears not being properly aligned to the cams. Often guys modify them and weld them, i have refused to install a set modified like this before due to crappy welding (cracks in the weld). As cincy said, cams are only needed in high tuned applications, 350 hp dosent need cams.
morre
Sep 2, 2010 11:38 PM
neur0tic
Jul 28, 2007 07:17 PM
AudiTim
Jul 27, 2007 01:31 PM
dankrohn
Jun 28, 2007 01:33 AM
apg96
Mar 7, 2005 11:15 PM
